wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
wardie
Thanks. I just tried with some normal 3.5" drive screws and the back pair (near SATA connector) slide past the metal case edge at the front OK as there is a bit of give at first, but the second pair in the middle don't as tray is running parallel by then. I'd rather not bend the case. I can PM you my address if you have some in the your UK office to stick in the post.
