wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
chirpa
May 29, 2008Luminary
As a temporary fix to get your disks installed, try stealing (1) screw from the other 3 trays to use on the 4th tray. So each tray will be short one screw, but would still be enough to keep them secure.
