wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
wardie
May 30, 2008Aspirant
Done. Disk 4 now initializing. Thanks. I would appreciate those extra screws still though to bring each drive back to a full compliment so I can be totally screwed :lol: .
Derivative question - I currently have nightly frontview backups set up off a snapshot. The initialization & volume expansion will likely run into the time window for these tonight. Do I need to disable snapshot & backups or will it work just fine off the 3 disks or ignore those actions until the 4th is online? I think I saw a post saying you didn't have to but I'm not sure and would rather know from the Force...
[edit: expansion finished prior to my nightly backups. Result! ]
