wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
wardie
Jun 20, 2008Aspirant
Well, I just purchased a ReadyNAS Duo as a backup solution (1x500Gb model) and guess what? It came with 8 spare screws giving me four for the spare drive bay in that machine, and four extra ones I can use on the NV+.
I'm assuming the drive trays (at least the screws) are the same - you can confirm? If so I will re-use them and don't need any from your UK people chirpa.
p.s. I would not recommend buying a Duo just to get four screws as it's substantially more than $5.99 :lol:
