wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
essd
Jul 04, 2008Aspirant
chirpa wrote: Confirmed. All the trays use the same screws.
wardie wrote: I'm assuming the drive trays (at least the screws) are the same - you can confirm?
To the forum admins:
Is someone able to confirm the actual measurements of the screws? The OP suggested that the screws were 6-32 4mm pan head, but based on my observations, it looks like 6 mm may be the correct answer. Is there an official answer to this question?
I know that we can buy these screws from the moderators, but I don't know if I can wait that long and I'd like to try to source them locally instead.
Thanks!
-essd
