wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
wdc77
Nov 04, 2008Aspirant
Hi Chirpa,
Any luck with the UK office re. getting replacement screws - mine went missing during my house move so can't get my Duo going at all (I had to pull out the drive cause it failed after only a month *groan*)
Cheers
Cheers
