wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
dbott67
Dec 04, 2009Guide
Bruce,
I believe that you can get these direct from Netgear for a nominal fee by calling support (# in my signature below).
Were the screws missing from the box or do you need extra?
The specs of the screws are as below, and should be able to order them from a specialty hardware store (or possibly a computer shop):
