wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
slawsonb
Dec 04, 2009Aspirant
They were missing. I have searched high and low for these screws from many vendors but no luck. They are a very rare size. This is why I asked where they could be purchased.
dbott67 wrote: Bruce,
I believe that you can get these direct from Netgear for a nominal fee by calling support (# in my signature below).
Were the screws missing from the box or do you need extra?
The specs of the screws are as below, and should be able to order them from a specialty hardware store (or possibly a computer shop):
