wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
dbott67
Dec 04, 2009Guide
I would contact support and see if they will send them to you for free. You could also try sending a PM to chirpa or Dooku to see if they can locate some for you.
-Dave
-Dave
