wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
mdgm-ntgr
Oct 07, 2010NETGEAR Employee Retired
chirpa are the screws at that ebay link the right size? That link says the screws are 1/4" which is about 6mm which from what you said earlier I think indicates they are the wrong size.
