wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
chirpa
Oct 07, 2010Luminary
Hard to tell from those images. 4mm or 6mm in length will work, just goes deeper into the HDD holes.
