wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
Zoosoup
Oct 12, 2010Aspirant
Hi,
You are right they are a little longer.... well anything up to 2mm as you can see below but they do still fit.
Andrew
Andrew
