wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
PapaBear1
Feb 26, 2011Apprentice
For a temporary fix, if you have one drive already installed, shut down the Duo and remove that drive. You can then remove two of the screws (diagonal pattern) and use them to install the second drive. If you have not installed the first drive, some screws can be removed temporarily from the chassis, the screws holding side panels on, etc. All the screws, except for the fan mounting screws, used to assemble the chassis are the same as the HD mounting screws. They are 6/32" x 4MM flat head screws. These may be difficult to find in the EU area.
There was a post by Zoosoup several posts above with a link to eBay.co.uk for drive caddy screws. Here is the link to the eBay listing. They are a little longer but will still work on hard drives as the threaded holes should be long enough.
