wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
PapaBear1
Feb 28, 2011Apprentice
Actually the trick of only using two screws per drive in a diagonal pattern was suggested on another discussion by a member of the Jedi. They do that as a matter of course in the lab. If they are working on various drives in various machines, it can be quite a chore to change out all those screws. The suggestion to "borrow" screws from the side panels and chassis panels was also suggested by a Jedi. Of course the only disadvantage to either is that it would be best to shut down the unit. But, a few more days won't hurt.
