wardie
May 29, 2008Aspirant
NV+ hard drive tray screws replacement
I've just bought an extra HDD to add to my NV+ thats been working fine for a couple of years now. However I can't find the original pack of remaining screws that came with it for fixing the drive to t...
Sandshark
Mar 28, 2013Sensei
Per information in another thread, they are 120 degree. I've successfully used 82 degree undercut 6-32 x 3/16 screws. They stick above the tray a bit, but have sufficient clearance. A standard 82 degree didn't engage well with the countersink. The undercut doesn't really engage with it properly, but it engages in a larger radius than the standard, so holds better. If I was willing to drill the holes a bit bigger, they'd have been a little more flush. The head on the 82 degree undercut is thinner than a 100 degree, so I suspect it's the better choice. I have no idea if the Dell 82 degree are undercut or standard.
