silviacity
Mar 17, 2014Aspirant
NV+ issues with odd LOG entries and excessive LLC
Hi All. Had my NV+ for 4 years now, 3 years in canada, and now 1 year in Australia with all of the original 2TB HDDs. In the australian heat i'm now getting a LOT of heat warnings in the logs bu...
Mar 17, 2014Guru - Experienced User
Yes, its disk 1. The current pending sectors (and the offline-uncorrectable) are the important indications here. They basically are the same as reallocated sectors. 557 is a high number, you should replace that disk without delay.
The best way is to hot-swap with the NAS running. I always recommend backups, you should make sure the backup is up to date before doing anything with drives.
