jturn00
Aug 11, 2011Aspirant
Nv+ issues?
Hi All, I came home from work and saw that my NV+ was off? No UPS but the power did not go out. Not sure why it was off. I turned it on and the boot cycle has been going on saying "booting..." ...
PapaBear1
Aug 14, 2011Apprentice
If you suspect a failed drive, it would probably be a good idea to shut the unit down and connect each drive to an SATA port on a desktop MB and run the vendor tools to test each drive.
However, if you are getting a corrupt root error on your LCD panel, you may be better off to work with tech support.
