amarzano
Aug 18, 2011Tutor
NV+ Replacement Issues
Folks - First - Thank you Netgear for replacing my NV+ after the Powersupply failure last week. Netgear sent me a new chassis and I promptly loaded it with the drives from my old unit. Strangely -...
PapaBear1
Aug 19, 2011Apprentice
What model is the new WD 2TB drive?
Have you run DataLifeGuard on the drive?
Have you checked the size of the the drive in disk manager? (another member and I recently had troubles with some Seagate drives that were showing a volume size smaller than normal and had to use SeaTools for DOS to reset to max native size. Then they were accepted).
