amarzano
Aug 18, 2011Tutor
NV+ Replacement Issues
Folks - First - Thank you Netgear for replacing my NV+ after the Powersupply failure last week. Netgear sent me a new chassis and I promptly loaded it with the drives from my old unit. Strangely -...
amarzano
Aug 19, 2011Tutor
I was able to get into Frontview.
Drive 1 is still not online and the re-sync tab still greyed out.
amarzano wrote: I am using the WD 2TB WD20EARS (which i believe was on the supported list).
I have used 2 different drives and both have the same result.
Per a response from Netgear support - I reloaded the O/S. This went well - but now I only see the outline of the Frontview screen and none of the tabs, etc. I used admin/netgear1 for the user password.
Any suggestions?
