robclarke411
Mar 18, 2012Aspirant
NV+ Slow Read in 4.1.7, 4.1.8 & 4.1.9-T6
Hi All,
I'm pretty sure there is never going to be a solution to this after trawling through hundreds of posts on this issue - but I thought I would ask anyway.
Like many others after I updated my 3x Netgear ReadyNas NV+ units from the 4.1.7 to the 4.1.8 firmware and my transfer rates sharply dropped. They went from:
4.1.7
Read 25MB/s
Write 19MB/s
to
4.1.8
Read 5MB/s
Write 16MB/s
After reading about all the various fixes it seems as though people either reverted back to 4.1.7 or updated to the 4.1.9 beta. I tried both, one on each NAS, the results were:
Reverting to 4.1.7
Read 12MB/s
Write 17MB/s
Updating to 4.1.9-T6
Read 8MB/s
Write 16MB/s
To say the least the results are worrying, these are official updates from a large multinational company with access to state of the art testing facilities. Were these updates not tested? So yes I can revert back to 4.1.7 but I still take a performance hit on what I had before. Obviously the process of reverting does not undo whatever problems the 4.1.8 update introduced. I know RAID systems are not a backup and I could factory default the NV+ and restore from my offsite backup. This is a huge pain though and will take a very long time before I'm back up and running. Has anyone else been in my situation? Experienced similar performance loss? and most importanly found a solution? I can live with a 12MB/s read speed but why should I when I know it is capable of 25MB/s! I just want to get back to where I was before.
Hopefully someone out there can help?
4.1.7
Read 25MB/s
Write 19MB/s
to
4.1.8
Read 5MB/s
Write 16MB/s
Reverting to 4.1.7
Read 12MB/s
Write 17MB/s
Read 8MB/s
Write 16MB/s
- robclarke411AspirantI should also note that my Write speed is now even higher than before so I have:
Read: 10MB/s
Write: 26MB/s - robclarke411AspirantAnyone?
- mdgm-ntgrNETGEAR Employee RetiredWhat happens if you reboot the NAS, do the read speeds go back up to 38MB/s?
- robclarke411AspirantI just deleted the NIC from device manager and deleted the driver, the rebooted and let Windows 7 rediscover the NIC. Am now back up to 25MB/s Read - I can live with this!
- NasinatorAspirantOne thing you can try, when you are getting low read speeds, is to stop it, and actually try writing a very small file to the NAS first. Then retry your read operation. Many times I have witnessed my read speeds increase by as much as 20-30% by doing this.
I can reliably re-produce this on firmware 4.1.7. I believe there is a fundamental flaw on initial session initiation for MTU negotiation during what I call "cold read operations." Meaning that your PC has no current TCP/IP sessions with the NAS device.
I've noticed however that actually writing a small file first (size is completely irrelevant). Then performing read operations greatly boosts the read speeds. My guess is that the write operation somehow correctly negotiates the MTU, thus making the performance better for reads.
One thing to note on this is that I use Jumbo frames with my device. So this scenario applies there. I cannot speak for the same situation on a normal MTU of 1500. I haven't tested it on normal MTU settings simply due to lack of time and resources.
I've been able to reproduce this phenomenon for a while now, but have not had the time to persue the actual cause at a packet level to provide proof that the problem actually exists. . . such is the life of physics majors lol. . . - robclarke411AspirantOk, duly noted - thanks for your input Nasinator!
- kcallisAspirantI just upgraded to the 4.1.9-T6 firmware, and suddenly I couldn't log into the admin screen. I ssh'd into the box, and was able to log in as root. I thought I could do a passwd admin and be able to reset the password, but no go. What do I need to do the change the password for the admin in order to log into the web interface?
- StephenBGuru - Experienced UserNormally you would do an OS reinstall from the front panel. Not sure how to do it from root.
- kcallisAspirantAfter I upgraded I logged in successfully. I removed the previous older version of samba (the add-on package). As soon as that was removed, I found myself back at a front view login. My original password didn't work nor did the default password. I was able to ssh into the box, and thought there a htaccess in place. But so far I have found nothing to change the frontview password from the command line.
- Tam1AspirantI have the same issue,
My uploads to the NV+ are excellent, easily maxes out my 100Mb 11.2MB/s and wireless network (300Mbps) around 13.9MB/s but downloading files from it is terrible...
100Mb ethernet or my Wireless around 4.4MB/s download ... yet changing to upload maxes my wireless out at 13.9Mbps (sure it'll go faster if i went gigabit, but just maxing out 100Mb on a download would be a start!)
