matt_hargett's avatar
Mar 18, 2012
[4.1.9-T6] samba crash and general feedback
First, let me say a big THANK YOU for upgrading the Samba to a version that supports SMB2. Several friends and myself had all manually upgraded to Samba 3.6.1 (and then to 3.6.3) in order to make iTunes usable. TimeMachine now finally appears to work for my husband's MacOS Lion laptop as well. It's great to have a supported solution.
Unfortunately, after the upgrade I am having multiple problems:
-the shares are no longer browsable. start+run->"\\nas" results in a failure.
-from my win7 login, I can browse to "\\nas\matt" and see the directory listing, but on the same machine, switching users and trying to browse to \\nas\geoff does not work at all (trying with IP address doesn't help). the directories are still there under /c/, and re-running smbpasswd doesn't help.
-under \\matt\nas, it takes minutes to load a 1MB JPG. this used to be instantaneous.
I've double-checked and cleaned up the Samba 3.6.x install (based on the flumps.org instructions), and there doesn't appear to be any conflicts.
One of the reasons we chose Samba 3.6.x was that 3.5.11 did not appear to be stable using SMB2 with mixed Vista/Win7 clients over the course of a few weeks. Maybe a final bump to 3.5.13 will fix the issues we saw, but 3.6.x is the only version they say has reasonably complete SMB2 support.
So, I'll be jumping back to samba-3.6.3, which allowed my iTunes library to be hosted on a samba share and quickly sync my iPad/iPhone. With 3.6.3 and a few config tweaks, my iPhone/iPad sync times went from literal days (sometimes without completing) to hours. (I'm running iTunes 10.6 on win7/x64.)
I'm happy to provide logs, or even remote shell access to aid in debugging. Or, if you guys are in the bay area, I can bring in my ReadyNAS unit. This is a fixable problem, just a matter of figuring out how to get the installable image to get there :)
Thanks again!
PS: When can we expect a similar bump to the openssl0.9.8u package and to the OpenSSH 5.x package?
ProSupport for Business
