matt_hargett
Mar 18, 2012Tutor
[4.1.9-T6] samba crash and general feedback
First, let me say a big THANK YOU for upgrading the Samba to a version that supports SMB2. Several friends and myself had all manually upgraded to Samba 3.6.1 (and then to 3.6.3) in order to make iTun...
mdgm-ntgr
Mar 21, 2012NETGEAR Employee Retired
The thing is that since you have installed samba yourself (even though you've removed it) it's difficult to be sure if the issue is beta related. It could very well be related to the installation of samba you made and if it is NetGear can't be expected to help with that. Now if you were to backup all the data on your unit, do a factory default (wipes all data, settings, everything) and still find the issue that would be a different matter.
