vitalious
Mar 22, 2015Aspirant
NV+ slow read speeds
Hello, I have a ReadyNAS NV+ running sparc 4.1.13. It's connected with cat 6 cables to an ASUS AC66U gigabit router. My NIC is also gigabit compatible. I have quite slow read speeds for drag a...
Mar 23, 2015Guru - Experienced User
Have you checked the SMART stats on the disks?
Also, it might be good to check for 4K alignment (and if the NAS is very old, the block size). There's info here on how to do that: http://www.rnasguide.com/2011/06/22/why ... -readynas/
