vitalious
Mar 22, 2015Aspirant
NV+ slow read speeds
Hello, I have a ReadyNAS NV+ running sparc 4.1.13. It's connected with cat 6 cables to an ASUS AC66U gigabit router. My NIC is also gigabit compatible. I have quite slow read speeds for drag a...
Mar 23, 2015Guru - Experienced User
You can specify 100 mbits to slow down gigabit if you want, but you can't uplift to 1 gigabit if the interface only negotiates 100 mbits.
Do the TCP retransmits increase during the test? They could be caused by packet loss on the PC link to the router. If so, throughput would go down.
