vitalious
Mar 22, 2015Aspirant
NV+ slow read speeds
Hello, I have a ReadyNAS NV+ running sparc 4.1.13. It's connected with cat 6 cables to an ASUS AC66U gigabit router. My NIC is also gigabit compatible. I have quite slow read speeds for drag a...
Mar 23, 2015Guru - Experienced User
The high load cycle counts usually mean that you didn't reset the head parking threshold on the disk. It might be worth doing that, but I don't think that is causing the low read speeds.
The three command timeouts on the other disks are a bit concerning (though the counts are low, so that also isn't causing the read throughput issue).
I'd try a different ethernet cable between the PC and the router (and possible the router ethernet port while you are at it)
