vitalious
Mar 22, 2015Aspirant
NV+ slow read speeds
Hello, I have a ReadyNAS NV+ running sparc 4.1.13. It's connected with cat 6 cables to an ASUS AC66U gigabit router. My NIC is also gigabit compatible. I have quite slow read speeds for drag a...
Apr 04, 2015Guru - Experienced User
Not really. 33 MB/s is for the "optimal" configuration. Your settings are closer to the default, which is mid 20's.
vitalious wrote: My speeds are not reasonable since the performance guide indicates I should be reading at 33mb/s, not 10
[quote="fbmachines"]The difference could be because of the green drives you are using. Green drives are lower performance drives./quote]I also use the same drives, and I am getting around 17-18 MB/s read speeds with my stock NV+. And that system doesn't have 4K alignment.
So I think the slow read speeds are still unexplained, but I am thinking 18-20 MB/s is the ceiling.
