kmm454
Jan 18, 2014Aspirant
NV+ SODIMM failed after RAIDiator 4.1.13 [SOLVED]
Update 01/21/2014 -- replacing the SODIMM in the NV+ appears to have solved this problem. No idea why the memory failed shortly after the upgrade to 4.1.13, other than coincidence, Murphy's Law . . . ...
mdgm-ntgr
Jan 18, 2014NETGEAR Employee Retired
http://www.readynas.com/kb/faq/hardware/what_does_this_light_pattern_mean
That means it can't find a valid RAIDiator firmware image and you should try USB Boot Recovery.
Before you try that though do you have the stock 256 MB RAM module in the NAS or a 3rd party 1GB module?
