kmm454
Jan 18, 2014Aspirant
NV+ SODIMM failed after RAIDiator 4.1.13 [SOLVED]
Update 01/21/2014 -- replacing the SODIMM in the NV+ appears to have solved this problem. No idea why the memory failed shortly after the upgrade to 4.1.13, other than coincidence, Murphy's Law . . . ...
kmm454
I tried USB Boot Recovery, but never get to the LED sequence at 5 seconds. LEDs 1 and 3 are constant and holding the Power button does nothing.
I pulled the RAM. It has a tag that reads "PC2700-1GB/200P-64x8" -- so I guess it was upgraded. The unit has been running reliably for 5+ years.
Any idea what the LED pattern means?
