kmm454
Jan 18, 2014Aspirant
NV+ SODIMM failed after RAIDiator 4.1.13 [SOLVED]
Update 01/21/2014 -- replacing the SODIMM in the NV+ appears to have solved this problem. No idea why the memory failed shortly after the upgrade to 4.1.13, other than coincidence, Murphy's Law . . . ...
kmm454
As I read the USB Boot Recovery instructions, "Connect the USB flash drive to any USB port and hold down the power button for 20 seconds until after
the hard drive lights blink the 4rth time. While you are holding down the power button, you will see the hard drive lights
flash at 5 sec, 10 sec, 15 sec and finally at 20 seconds."
. . . it's necessary for the hard drive LEDs to blink. They don't blink. Instead, LED 1 and LED 3 glow solid.
