kmm454
Jan 18, 2014Aspirant
NV+ SODIMM failed after RAIDiator 4.1.13 [SOLVED]
Update 01/21/2014 -- replacing the SODIMM in the NV+ appears to have solved this problem. No idea why the memory failed shortly after the upgrade to 4.1.13, other than coincidence, Murphy's Law . . . ...
mdgm-ntgr
Jan 19, 2014NETGEAR Employee Retired
So you still have the error in the LED pattern document. Might need to replace the RAM module with another.
