kmm454
Jan 18, 2014Aspirant
NV+ SODIMM failed after RAIDiator 4.1.13 [SOLVED]
Update 01/21/2014 -- replacing the SODIMM in the NV+ appears to have solved this problem. No idea why the memory failed shortly after the upgrade to 4.1.13, other than coincidence, Murphy's Law . . . ...
kmm454
Jan 20, 2014Aspirant
Wow, thank you!! This is very, very helpful.
I labeled each drive with the slot number when I removed them, so I'm hoping the drives are ok. I friend has a working NV+, so I'll see if he will loan me his unit to use for extracting the data, just in case the nonprofit's NV+ is fried.
I will post results. Thanks again!
