kmm454
Jan 18, 2014Aspirant
NV+ SODIMM failed after RAIDiator 4.1.13 [SOLVED]
Update 01/21/2014 -- replacing the SODIMM in the NV+ appears to have solved this problem. No idea why the memory failed shortly after the upgrade to 4.1.13, other than coincidence, Murphy's Law . . . ...
scootle
May 30, 2014Aspirant
Short follow-up... went ahead and ordered the exact same SODIMM from Amazon to see if my original part had indeed gone dead... and in fact it had. Call it a weird coincidence, but if you have this error, try a new CT12864 part. No idea if something in the 4.1.13 RAIDiator update itself could have caused hardware failure, but the timing is impeccable.
I'll see if Crucial will lifetime warranty the old (presumably defective) part so I have a spare for future use.
