Jappert
Mar 20, 2017Aspirant
NV+ Stuck on (hangs on) Booting...
It's actually a RND 4000 v3 (RAIDiator 4.1.15) 4x seagate Barracuda 2TB. I think it's RAID 5 (I know I'm supposed to know, but I don't... not for sure anyway) Hi there. My NV+ is stuck on Booting...
- Mar 21, 2017
You could also see if it boots with the bad disk removed.
JennC
Mar 20, 2017NETGEAR Employee Retired
Hello Jappert,
Try performing Skip Volume Check from the boot menu. Once you are are able to access, back up the data as soon as possible and then check for reallocated sector count and pending errors as well as ATA errors, these errors are from a faulty disks.
Welcome to the community!
mdgm-ntgr
Mar 21, 2017NETGEAR Employee Retired
