Jappert
Mar 20, 2017Aspirant
NV+ Stuck on (hangs on) Booting...
It's actually a RND 4000 v3 (RAIDiator 4.1.15) 4x seagate Barracuda 2TB. I think it's RAID 5 (I know I'm supposed to know, but I don't... not for sure anyway) Hi there. My NV+ is stuck on Booting...
- Mar 21, 2017
You could also see if it boots with the bad disk removed.
mdgm-ntgr
Mar 21, 2017NETGEAR Employee Retired
Jappert
Mar 22, 2017Aspirant
Yessss... that worked... Booting with the bas disk removed. (Booting with "skip volume check" didn't; it got stuck in the 'booting....' phase again) .
Much, very much appreciated...
(doing the extra back up right now...)
Could I also slip in a new 2T drive in slot 2 and have the system 'healthy' again, or is that too optimistic?
- SandsharkMar 22, 2017Sensei
Yes, after you have updated your backup, you should be able to insert a replacement drive. But since te resync process is drive intensive and losng the second drive during the process is catestrophic to your volume, you should always have a current backup before doing it.
