Ricardo_K
Feb 25, 2016Aspirant
NV+ v1 After firmware update shows Booting done!
After the new update the NV+ v1 rebooted and shows in LCD: booting..... done And nothings works anymore. I did a OS reinstall, no go. I did an USB Recovery, no go. Removed all drives and in...
Ricardo_K
Hi Stephen,
TestDisk just finished with Search.
1st Partition: Files are present and I can copy them (OS, no need for that)
2nd Partition: Support for this filesystem hasn't been implemented.
So, I can't continue with recovery.
Richard
Feb 25, 2016Guru - Experienced User
You could try R-Linux. Or possibly contact Netgear and ask about per-incident support.
- Ricardo_KFeb 25, 2016Aspirant
Thanks for the advice Stephen and give R-Linux a shot.
Will post my findings later on.
Richard
- Ricardo_KMar 01, 2016Aspirant
Well, R-Linux scans, finds partitions but can't open the (2nd/3rd) partition holding my files.
It can't open it at all.
Richard
- mdgm-ntgrMar 01, 2016NETGEAR Employee Retired
You may wish to consider contacting our support and purchasing any needed contracts for them to look into this.
We recommend backing up important data (note if NAS is primarily stored on your PC then a copy on the NAS is a backup as it is on a different device to the primary copy). No important data should be stored on just the one device (see Preventing Catastrophic Data Loss). This is especially true when using a device/disks that you've had for a long time.
