Mr_B
Dec 18, 2011Guide
NV+ V1 OS?
Raidar 4.1.8 is based on what, really? I know i've seen it somewhere, but i just cant seam to find it now. And of course, someone asked... So now i just got to find out again. B!
rodrigoprati
Dec 26, 2011Aspirant
mdgm wrote: Traditionally hard drives have used MBR partitions, however once you get to larger drive capacities than 2TB, GPT (GUID Partition Table) partitioning is needed. Sparc ReadyNAS can't handle this different kind of partitioning and so will see 3TB disks as <1TB in size.
RAIDiator 4.2.16 or later for x86, and all RAIDiators for ARM (beginning with the very first release 5.3.1) have GPT support.
Hi mdgm -- in searching for solutions to my unfortunate problem of having purchased a Duo v1 (I thought I was getting a v2!) and 2 x 2.5TB HDs, I'm trying to make them work even losing the 500GB on each drive. If the only problem is indeed the fact that they require GPT, do you see any other reason why it wouldn't work if I create an MBR partition of 2TB on each drive (http://www.rodsbooks.com/gdisk/mbr2gpt.html)?
Thanks!
