ciarpame
Feb 09, 2012Tutor
NV+ v2: advanced settings and recycle bin missing?
Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,... It's because Net...
mdgm-ntgr
Feb 09, 2012NETGEAR Employee Retired
ciarpame wrote: Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,...
No your not missing something. The "Disable Journaling" (not to be confused with "Disable Full Dat Journaling" option) of the v1 is obsolete on the v2 and x86 anyway so it wouldn't be included even if there were a performance options tab.
ciarpame wrote:
It's because NetGear decided not allow users to mess around with advanced settings or are they hidden somewhere?
If you know your way around SSH you can enable some of the missing things.
NetGear automatically choose settings for some things not configurable e.g. enabling disk spin-down.
