ciarpame
Feb 09, 2012Tutor
NV+ v2: advanced settings and recycle bin missing?
Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,... It's because Net...
ciarpame
Feb 09, 2012Tutor
Do you mean that I can enable more settings in the dashboard or that I can directly enable the settings via SSH?
Anyway I just installed SSH addon as described in a (your) another post, any clue about settings worth to enable or a way to re-enable recycle bin?
