ciarpame
Feb 09, 2012Tutor
NV+ v2: advanced settings and recycle bin missing?
Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,... It's because Net...
mdgm-ntgr
Feb 09, 2012NETGEAR Employee Retired
Do you have a v1 unit as well as the v2 or just the v2?
You can edit /etc/frontview/samba/Shares.conf (e.g. using vi - google for MAN page, also best to backup the conf file first in case you make a mistake and need to change it back)
A possible addition for a share would be e.g.
Then restart samba
vfs objects = recycle
recycle:versions = 1
recycle:repository = Recycle Bin
recycle:subdir_mode = 777
recycle:keeptree = 1
recycle:directory_mode = 777
Then restart samba
/etc/init.d/samba restart
