ciarpame
Feb 09, 2012Tutor
NV+ v2: advanced settings and recycle bin missing?
Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,... It's because Net...
mdgm-ntgr
Feb 09, 2012NETGEAR Employee Retired
I'm not sure. You could try adding it to /etc/samba/smb.conf in the global section (would advise against doing this though). Of course any modifications like this are unsupported but should work if done properly.
Take a look at http://www.samba.org/samba/docs/man/manpages-3/vfs_recycle.8.html
The settings for the recycle bin size are in /etc/frontview/recycle.conf
In the above example the recycle bin for media share is limited to 200MB or 10 days. In this example, I think old files will be removed to make way for new ones once the 200MB limit is reached and once a file is older than 10 days it will be removed. The script to clean the recycle bin is run daily.
The handy thing about the v1 is that you can make the setting you want in that and then check it via the command line and add it to the v2.
media!!/c/media!!200!!10
