ciarpame
Feb 09, 2012Tutor
NV+ v2: advanced settings and recycle bin missing?
Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,... It's because Net...
ciarpame
Feb 09, 2012Tutor
mdgm wrote:
The handy thing about the v1 is that you can make the setting you want in that and then check it via the command line and add it to the v2.
I saved a full configuration backup before shutting down v1, maybe I can find my previous recycle bin settings somewhere in the zip file.
