ciarpame
Feb 09, 2012Tutor
NV+ v2: advanced settings and recycle bin missing?
Am I missing something or a lot of settings previously available in Duo v1 frontview are now missing in v2 line? Examples: jumbo frames, journaling options, performance options,... It's because Net...
mdgm-ntgr
Feb 09, 2012NETGEAR Employee Retired
Should most likely be in the locations I mentioned above in that zip file. Manually copy across the changes you want.
