onimod
Feb 03, 2013Aspirant
NV+ V2 power button issues
The power button on my NV+ V2 at times becomes unresponsive.
The unit a backup to a pro and is configured to WOL (I found the timer to be too unreliable).
Generally I let the unit complete it's backup (pushed from Pro) and then I manually power off the machine using the button on the front.
Sometimes however the button is unresponsive.
I can shut the unit down using the Dashboard but the unit then won't power up with the button or WOL.
Unplugging and reconnecting the power appears to reset the machine and then is works as expected until the next time...
Can anyone offer some insight into the problem?
1 Reply
- WishAspirantI had experienced the exact same issue on my NV+ v2 last week
