hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
Snipe3000
Dec 09, 2012Aspirant
hauser wrote: dropping the journal is something you should only do if you understand the risks involved. most notably if you loose power while writing data to the drive you can risk loosing more than just the file you are writing to at that time. at least with a journal typically you only loose data that hasn't been safely commited to the journal/file system as it creates effectivly a audit trail of what data got changed so the system can replay after power outage to get back to a healthy system.
simplest way woudl be to use ex2 instead of ex3 or you could tell mkfs to not create a journal, but it's probably better to just keep the journal unless your prepaird to nurse a faulty file system back to health yourself as none of what's suggested in this thread is supported by NETGEAR afaik.
info posted within this thread is based on personal experinces and your experince following any of this may not result in the same outcomes that we had. so if your not confident in what your doing and you could somehow "trust" NEGEAR's terrible "remote access policy" they might be able to assist or fix it for you.
Thanks for the explanation. I'll forget about the journal then.
