hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
hauser1
Dec 15, 2012Aspirant
davexyz wrote: I have the same issue which has been elevated to Level 3 support still waiting for a reply. From what is reported here I can expect the answer to be "allow root access and let us set the file system up as ext3" So I have started this myself following the "instructions" in this post. I assume that XRAID 2 expansion operates as normal with an ext3 partition on the V2?
as far as i know XRAID-2 and Flex-RAID should work the same as it's a low level disk raid format and doesn't care what's stored on it, im never planning on putting bigger disks in this nas so i've just gone with Flex-RAID. i figgure i've had this much trouble with it so far im not going to be spending more money on it when a drive fails. that and i'll never be buying another NETGEAR anything after this unit...
