hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
Snipe3000
Dec 19, 2012Aspirant
Snipe3000 wrote:
hauser wrote:
Snipe3000 wrote: Hey guys, I started running into this stalling issue at about 85% and pretty much can't add anymore data to the device.
Sounds like I'm going to have to remove all the data before I can fix it correct?
I'm a bit new to this, but how do I convert the file format to ext3? Is that done within the web interface?
Thanks
for me i did the below to get it to work better for me (after removing/backing up data on the drives)
1) Update firmware to 5.3.7
2) in the webGUI under System -> Settings -> Performance untick "Enable disk write cache"
3) use enable root ssh addon http://www.readynas.com/?p=4203
4) ssh into nas and edit /etc/fstab (vi /etc/fstab)
change: EXT4 to EXT3 for mountpoint /c and save file (:wq)
5) reboot
6) mkfs.ext3 -m 0 /dev/c/c
7) tune2fs -O ^dir_index /dev/c/c
8) reboot
9) copy files to nas
effectivly that's what it summates to of all of what i've done to the device since getting it to get it to the point today where i could fill it untill it had ~30mb left free
still have an issue with delays in starting to copy larger files to the drive when it's 85%+ full, but it let me fill the drive.
Cool, It will be a little bit before I can try this, I have to get some new hard drives to backup the NAS (7 TB).
What is dropping the journal? is that something I should do as well?
Ok, I was able to get into the NAS using PuTTY, but I'm not stuck at step #4, when I type 'vi /etc/fstab' I get a list, but I'm not sure how to change it from EXT4 to EXT3 for mountpoint /c and save file.
