hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
Snipe3000
Dec 19, 2012Aspirant
davexyz wrote: I completed the steps and know nothing about linux. I discovered that vi is actually the command for the editor so first you have to "understand" how the editor works Simply you can move about with the arrow keys to enter edit mode you have to press [esc] key. then you can edit. You have to revert to command mode to save the file. google "vi editor" to get pages which describe the editor. and that should get you through that is what I did. sorry if this does not help
I was able to edit it, but now its all messed up, and I dont know how to reset it to start over. Does anyone know how to do that?
