hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
Snipe3000
Dec 19, 2012Aspirant
When I enter in Step #6 mkfs.ext3 -m 0 /dev/c/c
I get:
Could not stat /dev/c/c --- No such file or directory
The device apparently does not exist; did you specify it correctly?
** I did a factory reset and started over. That seems to have fixed the problem. I finished the steps for EXT4 to EXT3, and I'm only starting out with 2 drives in there for now.
There seems to be a recovery going on right now that's going to take 8 hours. Is this normal? Both drives are empty.
I get:
