hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
hauser1
Apr 24, 2013Aspirant
ihartley wrote: Here's a question that I worry about:
* If they release a patch that does not fix the problem, what is the risk that they release a patch that is detrimental (i.e. deletes data...)
If you don't know what you're doing (which you must not by releasing patches that don't work).........
50-50 depends how much you trust netgear to release a good patch.. very easy for them to have a patch that reformats the drives...
