hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
janforman
Jun 08, 2013Aspirant
davexyz wrote: What are the commands for this?
I assume I would ssh into the box
I have no linux so if you could post the commands as you did for setting up in ext3. I followed that
Thanks
You must use SSH access and replace ext3 back in /etc/fstab to ext4
then run this from prompt
tune2fs -O extents,uninit_bg,dir_index /dev/c/c
reboot now.
run filesystem check while you rebooting NAS (again)from web frontend.
